Reinstall Recovery Partition from DVD
brjohnsmith
I was handling Partition Magic and I deleted Sony Partition Recovery accidentally. I have saved the recovery in 3 DVDs before - from the original sony recovery process. So, How can I do to recovery this partition as it was?
I would appreciate it a lot for any hints...
tks.
rich912
Hi brjohnsmith,
To reinstate the HDD Recovery partition you will need to use your recovery DVD's to return your machine to factory settings.
Boot the machine with disk 1 in the drive. Once the Recovery Center has loaded select Restore Complete System and follow the instructions.
You will lose all personal data and third party software so backup anything you need.
Rich
Go n-éirí an bóthar leat
rich912
Hi brjohnsmith,
Rich
