Shut Down At Night Or Hibernate?
bingefeller
Hi folks,
I just recently got a Vaio VPCEJ2B1E and it's working very well.
My only question is whether it is recommended I should hibernate or shut down the computer at night?
For example, if I was working the next day, and I put the Vaio in hibernation mode it would be in hibernation mode for perhaps 18 hours or so.  If it was a weekend, or I wasn't working, and I put it in hibernation mode it would only be in this mode for 10 or 11 hours.
What is recommended?
Thankyou!
rich912
Hi bingefeller,
I personally would recommend shutting down if the computer will not be used for more than 4 or 5 hours.
Power consumption is minimal in hibernation but a restart will clear out the inevitable memory leakage that occurs when the OS is active for a prolonged period.
Rich
Go n-éirí an bóthar leat
bingefeller
Hi Rich,
Many thanks for the helpful reply.  I have actually got into the habit of shutting down completely at night time.  :slight_smile:  I think that, on your advice, I will continue with this practice.
Thanks again :slight_smile:
rich912
You're welcome bingefeller :slight_smile:
