Replacement button for vaio?
inked
Hi, Does anyone know if it is possible to obtain a replacement chrome buton for the touchpad / mouse one the Vaio AR21s as I have managed to take some of the chrome off of on of mine (Had something corrosive on my hand and didn't think before using the vaio)
The notebook is out of warranty so I would be looking to replace the piece myself rather than send it to Sony.
Any help would be apprecated
Have a look here for the part: -
http://www.nexttronics.com/reference/sony/ar2/ext-AR71DB.htm
You may have to e-mail them to confirm the correct part. The Touchpad Button looks expensive to me at over $60!!!
http://www.nexttronics.com/catalog/sony/2/268387501.htm
:thinking:
inked
Thanks, will give them a go
luineron
hi, part for ar51m is not in the catalog, hot to find?
