Restore Factory Settings
Darrono
I'm just wondering. If I revert back to the Factory Settings, will I lose my copy of Windows 7?
I bought the Vaio laptop with it pre-installed and the retailer did not supply any CD or Key or anything.
Many thanks
- Darrono
Message was edited by: Darrono
Hi Darrono,
No you will not lose Windows 7 if it was installed when you bought the Vaio.
If you revert to factory settings it will be as it was when you bought it.  You will not need to enter a Product Key.
:wink:
