I bought my vaio as a previously used display model and there are no drivers for the Ethernet card so I can't use theis! Is there any way I can get the drivers for it? I've searched on the internet without any luck.....
according to my pc rz424 the network card is an intel pro 100/ve card if that helps
hiya....thanks so much i managed to find the drivers and now the ethernet card works! :smileygrin:
i was jus wondering if you could help me out again though...
I need the drivers for:-
multimedia video controller
sm bus controlller
usb controller
do you think you could let me know the makes and stuff of those pieces of hardware, please?
The video driver is at http://www.vaio-link.com
If no-one else replies with details of the remaining drivers then Identify your chipset type and download and install the appropriate chipset drivers from the motherboard/chipset manufacturers - sisoft Sandra should help you identify the chipset.
hello...
I've already downloaded that video driver it's the multimedia video controller i need!
Will search for sisoft Sandra
