SAFEGUARD PRIVATEDISK
amj.designs
I HAVE TRIED MANY TIMES CONTACTING SONY ABOUT THIS PROGRAM THAT IS IN MY LAPTOP AND I HAVE BEING TRYING TO UNINSTALL,SONY COULD NOT HELP.THEY MAKE SURE THEY PUT THIRD PARTY SOFTWARE & PROGRAM ON YOUR LAPTOP BUT YET THEY DO NOT WANT TO HELP.I HAVE SENT 6 EMAILS TO THE MANUFACTER BUT YET NO REPLY.YOU CANNOT UNINSTALL IN ADD & REMOVE OR DELETE IN PROGRAM FILES EVEN ON THEIR SITE THERE IS NO REMOVAL TOOL AND THIS IS ONLY A TRIAL VERSION.HAS ANYONE GOT AN IDEA HOW TO UNINSTALL IT THANKS
12 REPLIES 12
amj.designs
well do i delete?the model is vgn-fj1s/w
tonybeard
OK I will find the link for you for your model and get back to you but in essence that is how you do it
rich912
This is the key you should navigate to:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Uninstall
Find the orphaned or, invalid software entry from the list (presumably ‘SAFEGUARD PRIVATEDISK’) and delete it. Close the registry editor.
Use this edit ONLY if all folders and files have been removed but the program is still showing up in Add/Remove programs.
If you are having difficulty removing the program or Folders/Files try in Safe mode (tap F8 at boot for this option).
Go n-éirí an bóthar leat
