SATA driver (intel) for sony pro 13 - Windows 8.1
SATA driver (intel) for windows 8.1 for Sony pro 13 won't install either manually downloaded or via vaio update? Have tried complete reset and have followed guidelines for updating from windows 8 to 8.1
5 REPLIES 5
mjboorman
I've go the same problem!! Any input from Sony support?
sgdavies
Sony Support? yes that is a good joke!
profile.country.ES.title
troglo
A month has passed and not a single official reply.
I´s satisfied with my VAIO Pro but I can´t recommended it to anybody with this level of (no) support
takrzem
Did you try installing it manually, via Device Manager - if it's possible?
Make sure you set Restore Point before doing so though.
troglo
Yes, as stated in the first message, Vaio Update and manual update fails both.
I didn´t try from Device Manager but I suppose it´ll be the same as the manual update
