hey everyone,
i have a Vaio Fe11h with windows media center. when i got it i uninstalled the screensavers and themes that came with windows. I want to re install the Aquarium screen saver and when i go to the add/remove windows components in the control panel it starts looking for installation files for it from the windows cd.
the problem im having is that i think the way Sony have the recovery cd structured i dont think i can locate the individual files needed for the screensaver on the cd.
can anyone suggest anything?
thanks!
All the files which are on a Windows CD are in the /i386 folder
ya i thought that, but i can't seem to locate the files at all for the screen saver. ah well i'll keep looking, thanks!
It's in a CAB - no idea which one
