I have a PCG-K315Z, which has a built in TV Output.
I am trying to use the TV output to display a second output.
Is this possible ... help would be very much appreciated !
So you want two screens connected to that one out?
You'll need a splitter cable, try Maplins
Sorry, don't think I explained properly...
I have a TV ouput in the laptop, so I can already have the same display on the TV and Laptop at the same time.
I am looking to get a different screen on the TV, instead of simply a copy of the Laptop screen.
ie. I use Winamp to play Karaoke tracks, I was hoping to get Winamp on the Laptop screen and the Graphic display from Winamp on the TV.
ie. one display on the "primary" display and a different display on the "secondary" display
You mean have > 1 desktop then?
Normally you can do this by dragging the application into the other montitor.
Hopefully someone else can explain it better, I have no use for that
