Please can someone help.
I have purchased a 250 GB hard drive to use as a second storage devise. this being a samsung spinpoint series SP2514N. But it shows as a 137gb drive on my computer.for some reason the HD has been limited from a 250 to a 137. the HD has been checked using the correct utility tool from the manufacturers. Please help as i'm at a complete blank as what to do to get the computer to recognise the correct size of the disk
My operating system is WindowsXP Home with SP2
My computer is a Vaio RX406
Try Format the same again.
Maybe a BIOS problem? If I boot my laptop with the Hitachi Feature tool, then it shows a maximal format-able size of 137GB too.:smileyconfused:
Hmmm, good to know. Because I aslo thought about to buy a extern harddisk. So 120GB seems to be the limit.:smileysad:
If you are using Windows XP then you must update your BIOS with the link Rob has provided, but you must also ensure you activate 48bit addressing inside Windows.
Microsoft Knowledge base - 48BIT LBA Addressing
The above article will guide you through a simple check to ensure your computer is compatible.
You could also use a Dynamic Drive Overlay from Samsung (if the hard disk came with a CD-ROM it probably contains such software). Using one of these often (but NOT always) elminates the need for a BIOS upgrade. This makes a simple adjustment that overcomes the BIOS limitations, allowing your computer to recognise this disk.
Thanks for that James, I forgot that the problem could be limited to the OS. I assumed the size was being reported incorrectly by the BIOS.
No problem Rob. Windows XP normally turns OFF 48-bit addressing which would require a patch to enable this support. The system BIOS can also have a problem, so its a case of elimination.
How about 50GB partitions?
No, that wouldn't solve the problem. The addressing mode has to be 48 bit to allow you to access all of the disc sectors.
Disk overlays should be avoided if at all possible - they can slow the computer and small errors can turn into total disasters. If the BIOS / OS mods don't work then the new controller card is the best solution. They aren't too expensive either.
