Please can someone help.
I have purchased a 250 GB hard drive to use as a second storage devise. this being a samsung spinpoint series SP2514N. But it shows as a 137gb drive on my computer.for some reason the HD has been limited from a 250 to a 137. the HD has been checked using the correct utility tool from the manufacturers. Please help as i'm at a complete blank as what to do to get the computer to recognise the correct size of the disk
My operating system is WindowsXP Home with SP2
My computer is a Vaio RX406
Hmmm, what about Network drives?
A few routers can connect a extern harddisk or a printer. Anyway, there are extern devices with space of 1TB and more. How would they work with this limit? Or do they use their own controllers?
Network drives have their own controllers and a few have their own interface software..
Sounds interesting.:smileycool:
And its a easy way to share files via wireless without to access another PC. Or using a media-center without PC. Hmmm.:smileythinking: Or not:smileyliar: ?
I should mention here that 48 Bit LBA support must be present in BIOS (therefore a BIOS upgrade will be needed), Service Pack One (1) for Windows XP or higher must be installed (Service Pack 2 recommended), and 48 Bit support switched on inside Windows XP.
If you switch on 48 Bit LBA support in Windows XP, without an up-to-date BIOS you risk catastrophic disk corruptions, destroying your data.
Seb: it's called a NAS, I posted about it in General Chat but no one had any ideas
Rob: yeah I was thinking that would be the problem.
If you're going to get a controller card might as well upgrade to SATA
