Hello, is that possible to add a second hard drive on VPCEC1C5E?
I have looked on the internet and found out that it has space for a 2nd harddisk but there is only a single harddisk cable?
The problem seems to be sourcing the additional cable and fittings.
You may find this discussion helpful: -
Thanks, I have read that. Does it mean I have to get a new cable? Does that thing sold on ebay or Amazon?
Actually when I get in BIOS, it shows my first hard drive and then the second hard drive as empty. It looks like I can install two hard drive, is that it?
