Sleep mode
Glyn-pc
Sleep mode
Hi All
How do i set the time period before my vaio goes into hibernation or sleep mode.
Thanks in anticipation.
Glyn...
rich912
Hi Glyn,
You haven’t stated your model by try this:
Click Start > All Programs and scroll down to and select Vaio Control Center.
Expand Power Management and select Vaio Power Management Viewer.
Click the Advanced button, scroll down to Sleep and expand. You should then have the option to set the period of inactivity on both battery and plugged in before sleep (click the blue text to adjust)
Rich
Go n-éirí an bóthar leat
rich912
Hi Glyn,
Rich
Glyn-pc
Rich.
I previously got to the power managment settings but would never have found the advanced.
Got there now though, good work!!!!!
Thank you
rich912
You’re welcome Glyn :slight_smile:
