VGN-N21 E/W Hard Drive replacement
castman
I am thinking about upgrading the hard drive in my VGN-N21E/W - a job I've done many times on a desktop computer, but not on a laptop.
Are there any step-by-step guides or nasty surprises lurking under the skin of the n21? I watched someone open up an Apple Macbook on YouTube and noted that there are special release clips which you have to be careful of, is there similar on the n21?
Thank you
rich912
Hi castman,
I’m afraid that it does involve delving into the guts of the machine to access the hard drive but if you feel confident about this then send me a PM with an email address and I will provide disassembly instructions.
Go n-éirí an bóthar leat
castman
Hi
PM sent - thank you for your help
