i try to use my mobile phone as a bluetooth remote control for weeks now but it still doesn't work.
notebook and phone have been paired and all other services (file transfer, com-port, ...) work properly. but if i try to register the HID-profile in my toshiba-software (add a new connection - k700i - human interface device) the following error occurs:
"This HID device is already registered"
starting the remote control from the mobile without adding the connection in the BT-software before leads to "bluetooth connection was interrupted" on the mobile screen...
i'm using a bluetooth mouse on the machine but even if i delete the bt-mouse-connection, the problem is the same.
it would be great if anyone could help me with that. tanks in advance!
hardware:
sony vaio vgn-fe11m
sonyericsson k700i
software:
bluetooth stack for windows by toshiba (v 4.00.20 (SO))
microsoft windows media center edition with SP2
Sorry you cannot do this but can you answer a question for me?
WHY DO YOU WANT TO DO THIS?!
because it's cool to sit on the sofa and switch through the playlist without walking to the desk... :smileygrin:
could you give me a short explanation why i can't do this? it worked fine on my last notebook with a usb-bluetooth-stick and widcomm stack.
yeah i got it working with the newest bluetooth stack. v4.00.36 solved the problem!
