Hi, I have a notebook VGN-A295HP, i bought it last week.
1º-My cpu is always lower then the expected (1700Mhz)! How can i make it run always at maximum speed?
2º-When i run some games, like fifa 2005 and nfsu2, my screen doesn't wide? Is this normal? Can i change that?
3º Can i upgrade cpu and memory without loosing warranty?
4º There is any way to change my graphic chip to a ati 9700 from a VGN-197(it's another notebook model)?
Thanks and sorry my english.:smileywink:
I'll go in reverse order.....
4. the VGN-197 is not a graphics card, it sounds more like a Vaio laptop. At any rate, a graphics card in a laptop cannot be changed.
3. CPU cannot be upgraded in a laptop. You can change the RAM without losing warranty.
2. Please explain what you mean by strain?
1. I suspect since your notebook is fairly new that is has a CPU that alters clock speed to save power when you don't need it. That's entirely normal, if you run a processor-intensive game and check the CPU speed again I'm sure it will be running at it's maximum.
LOL Tyger you have to be awkward don't you!
Please explain this "strain"
Hey I'm an amphibian you could cut me some slack on my arithmatic lol. I wonder if he means his games aren't running in high resolution?
Hehehe
I have no idea....:smileyidea:
Looks like Ian Hislop....
Tyger,
It is possible to change the CPU on a laptop, unless you already have the fastest in whatever family of processor is fitted.
Usual rules apply - same type, same socket, same FSB, same voltage and only as fast as the Mobo chipset supports.
Not for the faint hearted.
This will definately void any remaining warranty:smileygrin:
William
William he meant CPU speed not changing the actual CPU.
