SONY VAIO FE - LCD response time
alexpetros
hi!
someone knows what is the lcd response time of the vaio fe's series?
I'm very curious about that...:smileygrin:
THANKS!
6 REPLIES 6
biancavaio
do u meen how long it takes for the light frm the LCD to turn on .....that can be easily changed if u want light ...
right -click on ur batterie icon then press VAIO power mangement
then there should be a sign sayin LCD brightness ...then u just change the level of brightness
if u dont understand .....just ask ...
and ummm if this was'nt what u were lookin for sorry
xxx:smileygrin:
biancavaio
woops.....forgot to say .
when u right clik on the batterie icon preess ''adjust power properties '' ...then u may follow all the other instrcutions i gave
hope thats what u were lookin for
love b
xxx:smileywink:
alexpetros
thanks for reply but perhaps I'm not explain good what I would to know...
the response time of the lcd is a propriety that could't be modified...
...the display has a response time that can change from a pc to another pc...usually a good notebook lcd has a 16ms response time...and I want to know if my vaio FE has a lcd with 16ms of response time...
thanks for attention...and excuse me for mu bad english...:smileyblush:
biancavaio
oo sorry ...gave the wrong advice
did u add me on msn
love bianca
xxx
alexpetros
did u add me on msn
love bianca
xxx
no problem thank you very much for the time you've lost for me...
yes, i've added you in my msn, it's a problem?i hope it isn't so...:smileygrin:
biancavaio
hiya
no theres no problem .....dont worry im sorry i gave the wrong advice
hope it all worked out in the end
love b
xxx
