Hello All,
I have a new FE11M and i like it very mutch.
When i tried to install a fresh copy of Windows XP Media Center Edition everything is working except for the audio. There is no audio hardware regognized so i can't install a driver for it.
Is there a workaround for this "problem" ??
Greetings and tia
Hi Joecks and welcome to the forum.
Have you installed the UAA High Definition Audio Class driver?
Look at this thread.
Rich912,
Thanks for the quick reply, i will try if it this works.
Joecks
Did what you advised... working now
Many thanks...
Joecks
