Sony Vaio PCG 61111M running Windows 10 Home
timdamer
Hi, this elderly laptop runs well on Win10 Home. Only thing Device Manager showing Question Marks on Other Devices: "Base System Device" and "Unknown Device". Have searched for drivers but no result! Any advice /suggestions appreciated...
4 REPLIES 4
EdwinaU
Moderator
Hi Timdamer,
Welcome to the community.
Can you please let us know the model number of your Vaio then we can look into this for you.
It will be something like VPCCW1S1E.
Thanks,
Ed
timdamer
Thanks Ed. The model number is exactly as shown and printed on the original Sony laptop
label (although I do believe it may have an alias something similar to your suggestion)! But PCG 61111M is all I’ve got at present.
The S/N is 27506751 5002730 and the battery number is VGP-BPS13/Q – if that helps.
Many thanks for trying to help…
Tim D
PS Attached is Device Manager Screenshot
Hi timdamer,
Our fellow Sony Community member EdwinaU (Moderator) has just left a comment in a topic you're participating in. Take a look at what they have to say below:
________________________________
Re: Sony Vaio PCG 61111M running Windows 10 Home
Hi Timdamer,
Thanks,
Ed
EdwinaU
Moderator
Hi Timdamer,
Thanks for coming back with this information. We will check into this model and someone will update you when we find out more.
Best wishes,
Ed
Win_88
Specialist
Hi timdamer,
I looked at your VAIO and it doesn't seem that Windows 10 is supported on it. Which explains why there are no Windows 10 drivers on the support page. I'm afraid the best thing I can recommend to guarantee functionality is to roll back to windows 7.
Win_88
