hi
i am doing some project work that requires me to install windows 2000 as a second operating system, the problem i am having so far is that the drivers are all there except the following:-
---intel pro/wireless 2200 bg ( i have this driver from the intel website however it doesnt recognise it although in the XP operating system it is the same named driver- an of course i am intalling the drivers for win2k)
--i need the drivers for a 1394 net adapter i dunno how to install these to tell you the truth as i dont really know whether there are such drivers you can get for win 2k
-- i need the pcmcia flash memory drivers
can anybody help ---it will be appreciated
raf
HI, i have alrady tried vaio-link but to no avail.....
they only have windows xp drivers which i already have
does anyone know how to install net adapter drivers for a 1394 net adapter of such..
cheers
cheers
If you aren't planning on connecting any firewire devices than I wouldn't worry about installing the drivers.
have you tried installing the winXP drivers? they often work on windows 2000!
