Sony VAIO VGN-AR21S drive problems
Vandors
I have got Sony VAIO VGN-AR21S laptop. The Blu-ray drive doesn't work properly. There are 2 problems with it.
1. It doesn't read DVD-ROM disk. Doesn't see it, however disk is readable, was perfectly read at my desktop computer and DVD recorder. The laptop and disk are brand new. Bought 2 weeks ago.
2. Every software that reguires more than 1 CD to be installed just one after another can't be installed on the laptop.
System stops responding after second CD was inserted. However seperetly all they were read perfectly. Problem happens every time. Tried restarts, full system recovery and so on. Disks all new and readable on desktop computer. Tried 3 different software with the same result.
Can you comment all this and verify if it is a laptop problem.
24 REPLIES 24
Thalamus.
Champion
Hi Vandors
Welcome to Club Vaio, :slight_smile:
I would take your AR21 back to the retailer and ask for a replacement as you have only had your Vaio for 2 weeks and a system recovery has not solved the problem..:smileysad:
kee-lo_
I agree with Thalamus, but I'm not really suprised as they seem to have had a lot of bad bluray drives lately.
Vandors
The problem actually is that retailer refused return, untill Sony confirms it is a laptop problem..
They have log of this call and it could be confirmed..
BartK
Maybe check there download section.
It seems that there are new firmware available for this drive.
That might just solve the issue...:smileygrin:
Thalamus.
Champion
Hi Vandors
You may find HITS-UK's post in this thread of use..
apierc1
To my knowledge Blue Ray drives aren't able to play standard DVDs?? Standard DVDs and CD Roms are read by a red laser, and Blue Ray as sufggested by the name uses a Blue laser which allows more of the disk to be read or something, are they actually compatible? nothing I have read or heard has suggested they are.
Thalamus.
Champion
According to the Specs the AR21 optical drive supports the following:
CD-ROM : 24 x Speed
CD-R : 24 x Speed
CD-RW : 24 x Speed
DVD-ROM : 8 x Speed
DVD +R : 8 x Speed
DVD +RW 8 x Speed
DVD -R : 8 x Speed
DVD -RW : 6 x Speed
DVD Dual Layer : 4 x Speed
BD : 1.6 x Speed
BD-R : 1 x Speed
BD-RE : 1 x Speed
apierc1
Hmm I wonder if it's a dual laser drive? :thinking: Or maybe blue ray can just play standars discs? Interesting
Mingah
You can see two lenses when you open the drive, so it's most likely a dual drive
