Sony VAIO VPCEA1S1E
HalfzeRO
Sony VAIO VPCEA1S1E
I upgraded to Windows 10 on the Sony Vaio VPCEA1S1E laptop and now some of the symbols on the keyboard like (@ and #) don't work correctly, for example when I try to use @ I get " instead. I thought maybe turning on/off the num lock would resolve this but no luck I still get the same problem.
Hi HalfzeRO and welcome!
If you press SHIFT + 2 do you get the @?
If so, it looks like you have the US keyboard set as default. To set the UK keyboard, change the default language as ‘English (United Kingdom)’ and the keyboard layout to UK.
  1. Open Settings.
  2. Click on Time & Language.
  3. Click on Language.
  4. Under the "Preferred languages" section, select the current default language.
  5. Click the Options button. ...
  6. Under the "Keyboards" section, click the Add a keyboard button. ...
  7. Select the new keyboard layout.
