I have a Sony Vaio VPCF22S1E/B. I need a driver for Graphic card for Win 7 32 bit. Can anybody help me?Please.
I tried a lot of drivers and the problem persists.
I don't see any 32-bit drivers posted on the official website:
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VPCF22S1E_B
Some new VAIO models use generic graphics chip drivers. I'm not sure if the F22 is one of them, but checking the NVIDIA site is a good idea.
I'm not sure why you are using 32-bit Windows. Your VAIO comes with 8GB of ram, with a 32 bit OS you can use only about 3 GB. The OS uses about 1GB by itself, which leaves you with only 2GB to go. With a 64 bit OS - like the preinstalled one - you would have 7GB left and no chance to be limited by available memory.
Thank you for your answer.
I tried the NVIDIA site, but I hadn't any luck.
First I want to install 64 bit OS but I was afraid that not all the programs runs on 64 bit.
This days I will install Win 7 64 bit, because for this I have all the drivers.
