Sony vaio windows boost manager
Amy-lee
My sony vaio laptop had a heart attack today and came up with this screen.. I can not get out of it.. My "assist" button doesnt work because for some reason the vaio care was removed.. I do not have a disc and I have no idea how to fix this.. please help!!
8 REPLIES 8
EdwinaU
Moderator
Hi Amy-lee,
Can you let us know the full product name of your computer? There should be more numbers/letters after VPCCB.
Thanks,
Ed
IamNic
Hello @Amy-lee,
usually with OEM windows you either get a disk with the computer or are prompted to backup the Windows-Installation-files onto a DVD or USB-drive when you first set up the computer.
If you have neither one, you can simply purchase the same windows installation you currently have cheaply from amazon and repair the install.
- Nic
Hi Amy-Lee
Is this a Sony Australia model? Anyway, you can download the original utilities like Vaio Care from here:
https://www.sony.com.au/electronics/support/laptop-pc-vpc-series/vpccb35fg?downloads-num=91
I think that to repair your Windows installation you could borrow a Windows Disc from anyone with one and run the ‘Repair Windows’ from Windows Rescue on the Disc. You do not need a license key for ‘Repair’. You will need a Windows 7 disc. It used to be possible to download a rescue disc free if you don’t know anyone with one - try Google.
You are pressing ‘ASSIST’ with the Vaio completely shut down?
Amy-lee
The vaio doesnt work anyway so I don't know..  yes it's Australian.. It's off the assist button works but none of the other buttons do..  I WILL SEE  if a friend has a windows repair disc.. it's wiped everything off my external hard drive as well.. it went full spastic on me
Amy-lee
Yeah I have neither.. I've had the laptop for a LOOOONG time though..
Amy-lee
VPCCB35FG
Amy-lee
*Image removed by a moderator.
REASON: The image showed the Windows licence-Key.
NOTE: Please don't share software licence keys online on a public forum!
Do you know someone with a working Windows 7 operating system on their computer? If so, they can burn you a bootable windows repair disc from their computer.
https://support.microsoft.com/en-gb/help/17423/windows-7-create-system-repair-disc
Insert this disc in your Vaio and restart - your Vaio should boot from the disc and offer you a Repair Windows option.
