Sound stops working all of a sudden aftera random period of time
azam
I am running Windows XP on a Sony Viao PC. Using the speakers that came with PC.
The sound works fine, but then after a random period of time - whether it is a few minutes or a few hours - the sound stops working. I have tried absolutely everything, checking to see if mute is not on, trying different media players etc. etc.
It has been like this for over a year is frustrating. I have to restart the computer to make the sound work again.
Any idea what I could do to try to resolve this issue please?
Many thanks and Happy New Year to all :thumbsup:
5 REPLIES 5
Hi azam,
First of all let me say that I haven't a clue but personally, I would start by trying the following: -
1. Check that your Windows Audio Service is set to Automatic.
Start -> Right-Click My Computer -> Manage -> Services and Applications -> Services.
Scroll down the list of Services and have a look at 'Windows Audio'. Check that the Service is set to Automatic and is Started. If not, double click on it and choose Automatic from the drop-down box.
2. Try to install KB835221 instead of KB888111 or vice-versa.
The Microsoft UAA High Definition Audio Package has two versions. Check which one you have installed. Look in C:\Drivers\Hotfix and see if you have kb835221.exe or kb888111.exe. If your Vaio is a year old, you probably have the first one. Try updating to the second one (or the other way round).
As I said I don't know the answer but these are worth a try.
:thinking:
azam
Thank you very much for your advice.
I tried 1, but it was already set to automatic.
I couldn't find either of the files in 2. I look absolutely everywhere and did a search in every hard drive.
Any other idea what may be wrong? It's so frustrating to have a computer without sound 😞
rich912
Hi azam,
Re 2: Have a look in Control Panel > Add/Remove Programs. Make sure that you check the 'Show Updates' box at the top of the window.
Go n-éirí an bóthar leat
Hi Azam,
Just noticed the date you joined!! What model Vaio do you have?
I could have sent you on a wild goose chase if your model does not have Hi-Def Audio !!!!
:thinking:
azam
Thanks for the responses - really appreciate it.
I have clicked the 'show updated' box.
I have a Sony Vaio Pentium 4, 2.99 GHz. It is a Desktop and is two and a half years old. I bought it here in the UK.
Thank you once again.
