Special buttons problem.
Rida19
Hi, my vaio is a VGN-A115Z i am having a bit of a trouble with my special buttons as the brightness light is on all the time and the volume buttons stopped working. Also the CD/DVD disc eject button doen't work anymore for some reason. Can anyone help?? Many thanks.
4 REPLIES 4
knik777
you should install vaio utilities for your model to get this buttons work.
Thalamus.
Champion
Hi Rida19,
welcome to Club Vaio.. :slight_smile:
Download the Preinstalled Utilities from Vaio-Link, Use the following link: Sony Vaio Support preinstalled Utilities
Once downloaded extract the files and then install the following, in order.
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Once completed then re-boot your Vaio.
You may have to do this more than once..:smileywink:
Rida19
Hi Knik777 and Thalamus, your tips did the trick. Many thanks.
Thalamus.
Champion
You're welcome Rida19.. :slight_smile:
