Speedstep is not working anymore...
lipeuk
Hi Guys! When my Vaio VGN-SZ1HP came with everything original the speedstep was working fine. When I leave the power it got slower the processor. I reinstall everything again, all drivers and software but when I see CPUID the CPU is always in 1667mhz. Before it was 900mhz.
Any suggestions?
Thanks!
5 REPLIES 5
Thalamus.
Champion
Hi lipeuk,
Have you checked the CPU settings in Vaio Power Management, these options can be found in Control Panel > Performance and Maintenance > Power Options.
lipeuk
Yup! I set to Maximum Power VAIO and still it doesn't work.
lipeuk
lipeuk
any other idea guys?
JohnNL
Check your task manager....do you see only 1 graph or 2 ?
because i have a feeling my speedstep is broke as well....only showing 1 graph (1 core) instead of 2 !!!
