Standby mode hangs laptop with Vista ReadyBoost active on SD card
pistarino
Hi to all,
I am writing here about an issue I have with my Sony Vaio VGN-CS11S
I have Vista ReadyBoost feature active on SD card.
When I try to put my laptop in Standby while the SD card light is flashing, because Vista ReadyBoost is working on it, the following happens:
1) Monitor goes off
2) my CPU fan continue working
3) HDD light flashes (not continuously)
4) my pc does not enter in standby and when I try to resume it won't respond. If I click the power button on my laptop the battery light switches on, and go back to off when I release the button. I have to switch off the PC keeping the power button pressed for more than 5 seconds.
5) If I do not reboot manually, after about 5 minutes a BSOD appears with the following error:
"DRIVER_POWER_STATE_FAILURE" 0x0000009F
I have Vista SP1. All devices under Device Manager seem to be ok. I updated my laptop with all upgrades available on VAIO Update. I noticed the same problem also using another SD card.
I have no external devices attached (i.e. external HDD, USB Pen Drives, mouse, etc. excepted for the SD card, obviously).
Someone else has noticed this behaviour? Please help me!
pistarino
No one can help me?
No one has the same problem?
No one can help me in reproducing the issue?
:cry:
