Start up programs
tman16
Start up programs
Recently when i start up my laptop it does not appear to load all the programs every time. Sometime the wireless connection software and bluetooth loads other times it doesnt appear in the task bar.
Why is this and how can i fix it please?
5 REPLIES 5
Resonate
Firstly i would check if the applications are properly loading there is a good stat up manager located on Microsoft Technet sysinternals web site, The application is called auto runs
Microsoft / Sysinternals
If that dosent solve the problem try downloading the Process explorer its an awsome replacement for windows task manager
kee-lo_
This program, StartUpList is supposed to be better than MSConfig
Resonate
True this is a good program too KEE-LO forgot all about it,
Tman16 if you find that the program is running try clicking on your Taskbar then Properties at the bottom of the menu it should say hide inactive icons go to customise & look for your icon & check to see if it says always show if not click it to that then apply :wink:
tman16
thanks you 2, it works now
Resonate
No probs, I no how annoying it can be when things disapper without trace :cool:
