I want to watch my movies on TV played from the laptop using the svhs ouput connection. As my laptop has been rebuilt without any Sony applications what application can be used ?
I mean that using a Sony A217S laptop, using some software and a svhs cable connected, can I view it on my TV. Please any help will be helpful.
Regards
eM
You should be able to do this just by going into Control Panel > Display
Ive gone thru this after looking at previous post's. However the only monitor that shows is the Sony LCD Notebook. No graphical display of any other monitor. If I need to install maybe extra drivers or Sony software, what should it be, more to the point any links to them would be nice.
Ah ha, worked it out :smileygrin:
By installing the correct ATI drivers, this allows you to display the output to the specified source
