SZ Series Temperature
skykit84
Just a quick one, what temp does your SZ Series laptop run at?
I still think mines running too hot causing the fans to be on within 3-5 mins of the laptop being on.... after that, they never turn off!
The laptop is an SZ2XP/C which runs a Centrino 2.00/2gig ram/100gb HD
The Temp according to MM is
Freq: 2.00
Temp: 50c (runs around 46-50)
Temp 41c
Temp 43c
HDD #0 34c (usually between 34-38)
Can a few of you test out andpost back please?
Just need to know the temp the fans kick in, and when it kicks in... also what your normal day2day running apps like word, IE etc gets your temp up to.
10 REPLIES 10
thephongh
Hello,
Similar temperatures for my SZ3HP
I don't think it's a problem.
Pingu1
Hello,
What kind of software can I use to mesure the temp of my sz series? I have a sz1/xp.
Does it exist any program of sony for this task?
Thx.
Pingu1
Up!
Pingu1
Ok, I've discovered that MM means "mobilemeter"...
Thx.
skykit84
hiya, sorry for late reply, i only got an email tosee it was updated by you a few mins ago
yes its mobilemeter that i use
do let me know what yours hits
thanks
Pingu1
Hello,
Yesterday I could compare temperatures of my sz1/xp, and they were similar to those of your one.
I have a doubt of MobileMeter: the last two temperatures (41c) correspond at two cpu's, but the first one (50c) what is, of memory? motherboard? ...
Thx again.
xavante
i have a sz3xp/c and im using MM 0.3.1
im working in stamina mode with ultimate batery mode selected (using lvl 3 on display) and with cpu fan revolutions lowered for about 3h30min.
heres my values:
freq: 2.0
temp: 44º
temp: 43º
temp: 44º
discharge rate: 10.69w
hdd: 35º
skykit84
ah well looks normal
i guess now the only thing is why the fans always on
thanks
Pingu1
Is not normal fans always on? (but slower)
Regards.
