SZ1XP/C key replacement instructions
mikezoe
Can someone send me detailed instructions to replace a damaged key on the SZ series? Please email to mike(at)golfhi.fsnet.co.uk
thanks
Mike,
If you e-mail Tony Beard (one of the Club Vaio Experts) he will send you a copy of the official Sony instructions.
You will find his e-mail address in his profile - TonyBeard.
I think it is aklbeard AT netscape DOT net
:wink:
mikezoe
Received instructions today from Tony. Thanks for the lead.
I noticed that the instructions are headed by a list of models A,FS,K,FR & NV which does not include the SZ range- can I assume that the fitment is the same? If not any idea where I can get the right instructions?
regards
Thalamus.
Champion
Hi mikezoe,
Do the fittings on your SZ look the same as the ones in the guide that Tony set you.. :thinking:
If not you could try contacting Vaio-Link and request the correct instructions for your SZ from them..
