Hello,
Is it possible to turn of the (irretating) beep when the CPU load is 100%??
I'm making homevideo's and DVD's and during this process the cpu load is often 100%. It is no problem because it is still procesing but the computer is constantly beeping. And that is something that i want te be turned off.
Is this possible??
Thanks.
Yes the beeping is irritating but is there for a reason. It's telling you that the machine is overheating. Check to make sure there isn't a build up of dust on the fans.
As TR says the beeping is telling you it's time to clean it!
You need to hoover it
It sounds like quite a neat feature, provided it only goes off when it really is having heat problems. :smileygrin:
True
