Hi, hope someone can help.
My tv is no longer being recognised by my AR21s when I plug it in via HDMI, I get not options within display properties or Nvidia control panel.
Can anyone help?
You haven't mentioned which TV you are using - it makes a difference. How is it connected, HDMI?
Possible issues:
- HDMI cable faulty
- Wrong HDMI port if more than one
- Resolution set incorrectly to a format not supported by the TV. I think newer drivers auto detect the highest supported res, but older ones don't.
Are you using XP or Vista? What verison of drivers? Get the drift?
I had the same problem...
I updated the Nvidia drivers,... sins than i had this problem.
Try to instal the old Nvidia driver witch came with your laptop
rgrds
