TX: Keep the fan from starting all the time
negg
Another thing I want to share with the community:
On the TX the fan starts every 20 or 30 seconds for a few seconds due to the processor temperature around 60°C. I just managed to drop the CPU temp (as measured by MobilMeter) from constantly around 57/58 °C to less than 53 °C by using a tiny quiet external fan! The trick seems to be that you have to blow some air into the casing where it spreads around and cools everything a little.
No more internal fan operation could I notice since then. See my description here:
Negg's TX Minipage
While I don't find the TX fan to be overly loud (and am more concerned with how long it will stand that permanent operation) maybe this helps the ones that have louder fans.
Negg
0 REPLIES 0
