I have a Vaio PCV RS402 , the manual states that it supports USB 2 functionality , but for the life of me I can't see where to plug my camera in to take advantage of this , it seems to have what appears to be 4 normal usb ports on the back which i've contected to a hub ,please help
the usb 2 ports are the usb ports you have
dont hold me to this but is your hub usb 2.0 ?
but yes its the normal usb ports you have that are usb 2.0
hope this helps
I 'm not sure whether the Hub is usb 2 and the camera is connected to the hub so I will investigate further , thanks for your help
Use the front ones.
are the usb ports on a pcv-w2 usb 2.0 does anyone know please?:smileywink:
I believe you have usb 2 on your pc Glocks. You can check out this link.
http://vaio.sony-europe.com/PageView.do?site=ite_en_GB&page=ProductTechnicalFeatures§ion=Product...
