Vaio and Vista problem
MakTheDon
I have installed Vista and now I cant turn down/up the volume or mute with the "Fn" key well actually I cant use neither of the options with "Fn" key Anyone knows the reason? Thx
Some Vaios do -and some Vaios don't!!!
You can try reinstalling the Sony Preinstalled Utilities but if this does not fix the problem, you will have to wait for Sony to upgrade the software for Vista.
You don't say what model you have but download the Preinstalled Utilities from Vaio-Link and unpack then into a temporary folder. Install the Utilities in order:
1 Sony Utilities (installer folder 1)
2 Sony Shared Library (installer folder 2)
3 Vaio Event Service (installer folder ? depending on your model)
And then re-boot your Vaio - you may have to repeat the process!
:slight_frown:
