VAIO CAMERA CAPTURE CAPABILITY
Peteri
Hello,
Is it possible to record videos with sony vaio's built-in camera? on a model such as the vgn-fj3s/w.
Peter
20 REPLIES 20
Hi Peter,
Yes, you should be able to capture Video.
Start -> All Programs -> Vaio Camera Capture Utility
This gives you the option to capture stills or video.
:wink:
a7med_360
what about with the AR21S?
Should be exactly the same.
:thinking:
a7med_360
Sony vaio capture utility is not listed under my all program lists............also my camera disconnects automatically :slight_smile: cant find a solution for it
It should be - does anything at all work properly on your Vaio?
Have a look in C:\Program Files\Sony\VAIO Camera Capture Utility
:thinking:
a7med_360
:thinking:
thats what im wondering...... C:\Program Files\Sony\VAIO Camera Utility is what i have and it has two files one is Vaio Camera Utility Server and one is Vaio Camera Utility Setting GUI which neither of which launch
sometimes i think me vaio is cursed... i guess it wasnt meant to be :slight_frown:
Not Vaio Camera Utility - Vaio Camera Capture Utility
Remind me - I've lost track - are you running Vista or XP?
:thinking:
Peteri
Thanks again,
a7med_360
:thinking:
Well thats not there..............im running XP waiting for vista, but with all these problems with XP god help me with vista.......i had a thread about my vaio motion eye problems that it kept on disconnecting and i had to keep on un installating it then re-installing it to work but no one replied to that thread :slight_frown:
