VAIO VGN-C2Z display brightness
Eppu
Hello all,
do you think the display of your C2Z is bright enough? I've be looking my new VAIO for about
a week now and I find its screen a bit dark. And in the down left corner there is a clearly
visible shadow (best seen in white www-pages). Brightness-control is in the top. Should I contact the service or am I just imaging?
Thalamus.
Champion
Hi Eppu,
welcome to Club Vaio.. :slight_smile:
Without seeing your screen it's hard to say if it's normal, if you are concerned then either contact Vaio-link or take your Vaio back to the retail outlet and compare your screens brightness with another C2Z..
