Vaio Care disk cleaner emptyies recycle bin regardless.
dayumDayumDAYUM
Does anyone know why the Vaio Care disk cleaner function would continue to empty my recycle bin despite the recycle bin tick box in settings being unchecked? Has anyone else found this?
Model: VPCEB3J1E
Vaio Care version: 8.4.3.07161
Thanks.
jumpsuit
Hi @dayumDayumDAYUM
Sounds odd, although I'm not running a Vaio at the moment so can't test it myself for you.
I haven't seen any other members posting about this problem yet, but it would be interesting to know if others  are having trouble too.
Apologies if you have already tried this but have you tried checking the box then saving settings, then unchecking it again, saving the settings and then running Vaio Care again?
