VAIO Care has stopped working
Evergreen91
I have an ALL IN ONE PC(VPCJ21M1E) purchased in Jan 2012.
Every time I boot up I get a message "VAIO Care has stopped working. Click for solution or Close Program".  No result from "Click for solution"
Manual (Page 25) says "To launch VAIO Care press ASSIST button.  Done this nothing happens.
Going to the Start Button and" Programmes - VAIO" brings up the message "VAIO Care has experiencd an error.  Please restart application".  Doing this brings up a repeat of the same error message.
Have looked at VAIO Web Site but, as expected, it is a veritable minefield, hence my recourse to the Community in hope that some kind soul will help me.  I would be most grateful.
Evergreen91
Thanks Rich. I'll have a go at this later and come back to you.
Brian.
6 REPLIES 6
rich912
Hi Evergreen91,
There were numerous reports of this problem a couple of years ago – I don’t remember any recent problems but you may find this thread of some help…
http://community.sony.co.uk/t5/PCs-Accessories/Please-help-me/td-p/339930
I can’t see any updated Vaio Care for your model but you could try uninstalling Vaio Care from Control Panel and then reinstalling the original program from the preinstalled drivers and utilities section for your model ( I assume you are still running Windows 7?).
http://www.sony.co.uk/support/en/product/VPCJ21M1EB/updates
If this is a recent problem you could also try a system restore back to a date when you know that Vaio Care was working.
Rich
Go n-éirí an bóthar leat
Evergreen91
Thanks for your repy Rich. Yes I am usung Windows 7, and Google Chrome, but am having difficulty uninstalling VAIO Care.   When I click 'Uninstall' in the Control Pannel I get "Programme is running", so I go to the Task Manager and stop the programme but get the same answer when I return to the Control Pannel and try to 'Uninstall' again and again.
Have to go out now but will look for your reply later..
Brian
rich912
Hi Brian,
I can’t say I know what the problem is but try uninstalling in Safe Mode.
Rich
Evergreen91
Brian.
Evergreen91
Hi Rich,
Thanks to you all is now well except that the ASSIST button still doen't respond but, as this was the first time I had tried to activate it I shall never know whether it ever did work. Still, I reckon I can live with that, so thank you very much for your help.  This was my first post in this forum and I am delighted that it was so successful.
Best regards,
Brian
rich912
Hi Brian,
I’m pleased to hear Vaio Care is now working.
Does pressing ASSIST when the computer is fully shut down launch Vaio Care Rescue? Also, do all the general Fn (function) keys (e.g. brightness and volume) work?
Rich
