VAIO Fit 13A SVF13N1C5E - VAIO Update - 500 Internal server error
fnisse
Every time I try to update my new SONY VAIO using VAIO Update, I get an error message (500 - Internal server error - There is a problem with the resource you are looking for and it can not be displayed) and no updates can be found.
I have been in contact with the local support but they havent been able to explain this or to come up with a solution. Anyone else having this problem and found a solution?
Thalamus.
Champion
Hi fnisse,
I have been informed that your Vaio's serial number has been uploaded to the server, could you check & confirm that you can use Vaio update without any errors please.?
12 REPLIES 12
Thalamus.
Champion
Hi fnisse,
welcome to the Sony User Community Forum..:smileyhappy:
This has been mentioned before, the 500 Internal Server error normally appears when your Vaio's serial number has not be added to the server..
I'll forward your post to one of our contacts in a hope that they can help, if, & when, I receive a reply I'll update this thread..:smileywink:
fnisse
Hi Thalamus!
Thank you for your quick reply and help!
Thalamus.
Champion
Hi fnisse,
fnisse
Hi again
Yes it's working now.
Thanks again for your help!
Kind regards
fnisse
Thalamus.
Champion
You're welcome, glad I could help..
Sofwat
Hi, I have the same problem. Please help?
Sofwat
Hi, can you add my number to the server too please?
Thalamus.
Champion
Hi Sofwat,
Thalamus.
Champion
@rich912 one of the other Experts has already flagged this problem for some other Vaio owners on this forum and the feedback is the same, please see a copy of his reply is below..
rich912 wrote:
I’m informed that serial numbers for all three machines should be registered with the database some time before the end of this week. Keep trying intermittently and let us know when it works.
Rich
