vaio pcg 81113M processor upgrade
dwcowan75
I have upgraded my vaio to 8GB RAM and put an SSD in. I am looking at swapping out the processor. Does anybody know what processor I can upgrade with (I dont know the socket type)
Showing PCG 81113M as the model type on the back on the laptop
any help appreciated
4 REPLIES 4
Hi dwcowan75 and welcome.
You have quoted the chassis type, so all I can tell is that it is a 16.4" Vaio laptop. All the F Series Vaios share the same chassis.
Can you please try to find the correct model - it will be something like VPC F13M1E.
You will find it on the screen surround or in Vaio Control Centre or in the BIOS.
:thinking:
dwcowan75
Sorry about that I have the following VPCF13M8E
hope that helps
dave
Your Vaio has an i7 Quad Core processor - Intel® Core™ i7-740QM so it should be fairly quick already.
The only worthwhile Socket G1 upgrade would be to a Intel® Core™ i7-940XM.
This would give a substantial increase in power BUT it consumes an extra 10W (55W instead of 45W) and I am not sure the F-Series Vaio could handle the increased heat. I seem to remember the VPCF13 models were prone to overheating, so the upgrade would not be without risk. It is also an expensive upgrade.
:wink:
dwcowan75
thanks for the reply, I had a look at the prices - you are right quick an expensive upgrade. Might just soldier on for a while then look at replacing the laptop
