VAIO PCG-F807K EXTEND WINDOWS DESKTOP
ravaion
Does anyone know if it's possible to use the "extend my windows desktop" on a VAIO PCG-F807K? In the Display Properties there is only one monitor icon and there is no option to extend. The graphics card is ATI RAGE MOBILITY on Win2KPro. Thanks.
kee-lo_
I don't think it supports dual monitor as it's only 8MB VRAM
ravaion
Thanks for the reply. And I guess upgrade is not possible, ?
I have another question, not sure I should post it in a different topic area: can anyone recommend a backpack for a VAIO S, preferably one strap? I'm trying to find something light (to keep the weight down) but robust. Maybe you could point me in the right direction. Thanks.
kee-lo_
Sadly it's not upgradable.
Targus do great back packs for notebooks. Thats targus.co.uk
