Hi
Just wondered what people thought of the PCV-RS222, does anyone else have one?
I bought an end of the line base unit near the start of this year and that was quite expensive.
Didnt mind paying it though being a sony and all.
The graphics card seemed a little low end ( FX5200 128meg ) but I notice that unless you build your own, most top spec pc`s are coming with the fx5200 nowadays.
Does anyone have any problems upgrading hardware?
I was thinking of getting rid of my 300w power supply, putting a 450-550w one in and getting a high end graphics card. May need loads more fans though - has anyone experienced any problems with this and do you foresee me having any problems if I do this with my PCV-RS222?
Regards
Jim
You will have problems with the PSU as it's non-standard size.
Most people have had no troubles with upgrading the graphics card.
