wireless on B1VP
evilswan
wireless on B1VP
hello! wireless on the b1vp seems to work fine, i was wondering - where is the antenna located on the laptop and is it possible to attach an external antenna to increase the range?
5 REPLIES 5
kee-lo_
The antenna I think is inside the screen's besel.
You can't add an extention.
Akanksha
although i have sometimes seen that ur hands working on the keyboard improve reception tremendously, its a fact!:smileylaugh:
kee-lo_
:laughing:
evilswan
to be honest, i was amazed at the reception! in my house i can pick up my own network, but i can also see about 3 other encrypted APs (which i don't connect to, obviously).. just thought it was pretty impressive!
i would like to add an external antenna for work though, as the laptop moves around the premises a lot and loses signal at the far end of the warehouse.
i guess the only option is to buy a PCMCIA wifi card with an external antenna port?
kee-lo_
Yes, but I would test out a co-worker's card before purchasing.
