I hope somebody will be able to help me on this, as e-support is not working at all.
I bought a couple of weeks ago a S2XP, and overall I am very happy with it.
In the last week, my "VAIO Power Management" tab placed in the "Power Option Properties" dissapeared. "VAIO Power Management Viewer" refuse to work because "VAIO Power Management" is not activated. It looks like this feature have been uninstalled in any way from the PC.
It's weird as I did not perform any uninstallation of any software. Do you know any way of fixing/reinstalling it? I didn't try with the "VAIO Recovery Tool" as I do not want to loose my data in C:
Many thanks for your help.
It's confirmed. I have several missed files regarding the Sony Power Management (althought the windows registry still points to them). The only power management files that I currently have installed are for the Power Management viewer.
Missed files (at least this ones, maybe others):
C:\Program Files\sony\vaio power management\SPMgr.exe
C:\Program Files\sony\vaio power management\SPMPanel.dll
C:\Program Files\sony\vaio power management\SPMDAM.dll
C:\Program Files\sony\vaio power management\VSyncGUI.chm
As the e-support don't work, do you know any support email to ask which package/utility contain these files?
The best thing to do is call I'm afraid.
I would suspect they're in one of the PAC files, google is your friend, we're not allowed to give out the full info.
Strange
Yes, it's really strange.
I just called Vaio Support, and the only solution that they could offer me is to recover the whole C: partition. As this is not an option for me, could any of you with a S2XP (or S1XP/S2VP...) please zip your whole "vaio power management" folder and send it to me? Maybe replacing the missed files will do the job, as the registry settings are intact.
The folder should be located in:
The files that are missing are (at least):
(but I would prefer to have all the files as I am unsure if those are the only ones)
I am not sure if Sony would allow forum members to distribute their software, good intentions or not - I may be wrong but I think Sony would frown on this...
Would it not be better to backup your computer first, then do a full recovery?
I don't know James..... that's up to the individual who does it. Really I can't see a problem as he owns the software anyway
Aye, and I didnt see anything in the announcements area either so I guess its OK... The software is licenced and its not piracy after all...:smileywink: :smileygrin:
Then again I bet Sony don't have this outlook, they probably see this as DLL piracy
Well, I thought this can not be considered piracy as I own a license of the software :smileytongue:. Just in case, I will not ask for it in this forum again. As Kee-Lo said, google is my friend
Full recovery is not an option at the moment. I don't have free time at all for reinstalling & reconfiguring my PC, in my case it takes a long time.
If only the Vaio staff could send me the installation files for it... this is the problem with the automatisms like Vaio Recovery software: when a non-standard problem arise (and there are lots of these problems) it's a useless <profanity removed by moderator> xD I would prefer to have all the soft & drivers in the tradicional way. With no doubt.
