Hi, I've just formatted my vaio vgn-tx1hp notebook and have been installing most of the utilities that came with it, but I cannot find the funky vaio toolbar utility?
Can anyone help?
Daz
Hi redukdaz,
Welcome to Club Vaio,
The tool bar you are looking for is called Vaio Launcher, this can not be found in the drivers and utilities..
To install the Vaio launcher, you have to recover your Vaio to it's original state using either the the recovery disc's that you created or the hidden recovery partition, however as you mentioned that you formated your Vaio you may have removed the hidden recovery partition in the process..
errummmm
Let's go on the assumption I have
Daz
Hi redukdaz,
Did you create a set of recovery disc's before you formatted your TX1?
If you did not, all is not lost you can always purchase a set from Vaio-Link should you wish to restore your vaio in the future..
