Vaio VGN-AR51SU disc tray open button not working
DonkeyDog
I have upgraded from Vista to Windows 7. I have installed all the Drivers recomended by Driver Toolkit software. I have installed and run Vaio Update.
Only one problem, the disk tray open close button does not work.
I can open the tray from Windows Explorer, but only if there is a disk in the tray, if not I must use a pin to open the tray manually.
I guess that there is some other driver required, but Device Manager show no problems.
Anyone got any suggestions??
20 REPLIES 20
DonkeyDog
Thank you for that utility
I will try it this weekend.
Regards
