Vaio with Vista Business Losing Internet Connection.
deeyes
Vista Business losing internet connection!
Hi, i own a new SZ4VWN/X, which came preinstalled with Vista business. My problem is i am losing my internet connection when switching between users. It will reconnect after about 30 seconds, but its just frustrating when a differant user logs on and has to wait for the internet to reconnect. My router is a NETGEAR.
Is the problem my Vaio, Vista Business or Router?
Anybody have any ideas?.
kee-lo_
Windows XP had a similar issue if I recall correctly
Yes Kee-Lo, the same thing happened in XP.
There was a Registry fix for XP:
Click Start --> Run and type regedit
Navigate to this key :
HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows NT/CurrentVersion/Winlogon
Then right-click the right-hand pane, select New/String Value.
Name the value KeepRasConnections
Double click the new key and set it to 1.
Don't know if it works with Vista
:thinking: :thinking: :thinking: :thinking:
deeyes
Thanks for that guys, i will give it a try.
